Autonomous Fruit Picking Logo
Overview
  • Digital Twin Safety for HRI
Test Environments
  • Comparative Analysis
  • Isaac Simulation
  • Gazebo Classic
  • Gazebo Fortress
Safety Protocols
  • Robotic Protocols
  • Pertinent Standard: ISO 13482
  • Pertinent Standard: IEEE P7009
Data Protection Policies
  • Retail Robot Operations
  • Privacy Protection
Person Detection
  • ZED 2i Overview
  • ZED 2i Relevancy
  • ZED 2i Compatability
ROS2 Navigation
  • Nav2 Local & Global Planners
  • Nav2 Key Parameters
  • Nav2 Experimental Parameters
Experimentation
  • NavFn Planner + DWB Controller
  • NavFn Planner + MPPI Controller
    • Why MPPI Controller is a Good Choice
    • Relevant Parameters for MPPI Controller
    • Testing Scenarios and Observations
    • Performance Summary
    • Conclusion
  • NavFn Planner + RPP Controller
  • Theta* Planner + RPP Controller
  • SMAC Planner + MPPI Controller
Results
  • Nav2 Performance for Safety Scenarios
  • Nav2 Suitability for Different Robots
  • Nav2 Controller Suitability for Different Robots
  • Conclusion
  • View page source
This configuration utilizes the NavFn Planner for global path planning and the MPPI (Model Predictive Path Integral) Controller for local trajectory optimization. This combination is designed to balance efficiency, smoothness, and dynamic obstacle handling.
The MPPI Controller is well-suited for dynamic environments requiring real-time adjustments. It optimizes trajectories by considering the robot’s dynamics and environmental constraints, making it highly effective for:
  • Dynamic Obstacle Avoidance: Evaluates multiple trajectories to select the optimal path while avoiding collisions.
  • Smooth Path Generation: Produces jerk-free motions for stable operations.
  • Real-Time Performance: Delivers responsive and efficient control in dynamic scenarios.
MPPI Controller Parameters
Parameter
Value
time_horizon
1.5
Time horizon over which the trajectory is optimized.
desired_linear_velocity
0.5
Target velocity for the robot’s linear motion.
desired_angular_velocity
1.0
Target velocity for the robot’s angular motion.
linear_acceleration_limit
2.0
Maximum allowed linear acceleration for smoother motion.
angular_acceleration_limit
3.0
Maximum allowed angular acceleration for smoother turns.
optimizer_iterations
1000
Number of iterations for trajectory optimization in each cycle.
cost_weights.path_following
10.0
Weight for staying close to the planned path.
cost_weights.collision_avoidance
15.0
Weight for avoiding collisions with obstacles.
cost_weights.smoothness
5.0
Weight for ensuring smooth trajectories.
lookahead_dist
0.6
Distance ahead of the robot for trajectory optimization.
transform_tolerance
0.1
Tolerance for transform lookups to ensure stability in real-time adjustments.
visualize_optimizer
true
Enables visualization of the optimized trajectories for debugging in RViz.
The robot’s performance was evaluated under three scenarios using this combination:
  1. Straight-Line Movement - The robot followed a smooth and precise trajectory with minimal drift. - Real-time trajectory optimization ensured stable motion.
    Straight-Line Movement GIF
  2. Navigating Static Obstacles - The controller successfully adjusted the robot’s path to avoid obstacles, maintaining smooth transitions. - Dynamic trajectory optimization minimized unnecessary deviations.
    Static Obstacles GIF
  3. Navigating Dynamic Obstacles - The robot responded effectively to moving obstacles, recalculating the trajectory in real time. - The robot maintained a safe distance from the moving object. - Optimized control commands reduced delays in avoiding faster-moving objects.
    Dynamic Obstacles GIF
Performance Summary
Performance Summary
Scenario
Performance
Smooth and precise navigation.
Static Obstacles
Reliable obstacle avoidance with smooth trajectory adjustments.
Dynamic Obstacles
Effective real-time responses to moving obstacles.
Conclusion
The combination of NavFn Planner and MPPI Controller provided robust performance across all scenarios. Its ability to handle dynamic obstacles and generate smooth trajectories makes it an excellent choice for complex environments.
Future Improvements: - Further tuning of cost weights and time horizon could enhance responsiveness in highly dynamic settings. - Exploring alternate global planners, such as Smac (Hybrid-A*), may yield better path efficiency for intricate environments.
Previous Next
© Copyright 2025, MyBotShop GmbH.
