Autonomous Fruit Picking Logo
Overview
  • Digital Twin Safety for HRI
Test Environments
  • Comparative Analysis
  • Isaac Simulation
  • Gazebo Classic
  • Gazebo Fortress
Safety Protocols
  • Robotic Protocols
  • Pertinent Standard: ISO 13482
  • Pertinent Standard: IEEE P7009
Data Protection Policies
  • Retail Robot Operations
  • Privacy Protection
Person Detection
  • ZED 2i Overview
  • ZED 2i Relevancy
  • ZED 2i Compatability
ROS2 Navigation
  • Nav2 Local & Global Planners
  • Nav2 Key Parameters
  • Nav2 Experimental Parameters
Experimentation
  • NavFn Planner + DWB Controller
  • NavFn Planner + MPPI Controller
  • NavFn Planner + RPP Controller
    • Why Regulated Pure Pursuit Controller is a Good Choice
    • Relevant Parameters for Regulated Pure Pursuit Controller
    • Testing Scenarios and Observations
    • Performance Summary
    • Conclusion
    • Interconnected Nodes in Nav2 Stack
  • Theta* Planner + RPP Controller
  • SMAC Planner + MPPI Controller
Results
  • Nav2 Performance for Safety Scenarios
  • Nav2 Suitability for Different Robots
  • Nav2 Controller Suitability for Different Robots
  • Conclusion
  • View page source
RPPC (Regulated Pure Pursuit)
This configuration utilizes the NavFn Planner for global path planning and the Regulated Pure Pursuit Controller for local trajectory adjustments. While this combination is highly efficient for straight-line movements, its performance diminishes when navigating through close proximities or dynamic environments.
The Regulated Pure Pursuit Controller is known for its simplicity and reliability in following global paths, particularly in open environments. It is designed to scale its velocity based on proximity to obstacles and path curvature, ensuring smooth and precise motion.
Key Advantages: - Ideal for Straight-Line Movements: Ensures smooth and predictable navigation without significant path deviations. - Velocity Regulation: Dynamically adjusts speed to maintain safety when approaching obstacles. - Ease of Tuning: Fewer parameters compared to more complex controllers, simplifying configuration.
Regulated Pure Pursuit Controller Parameters
Parameter
Value
desired_linear_vel
0.5
Target velocity for the robot’s linear motion.
lookahead_dist
0.6
Distance ahead of the robot for trajectory adjustments.
min_lookahead_dist
0.3
Minimum distance for trajectory adjustments.
max_lookahead_dist
0.9
Maximum distance for trajectory adjustments.
rotate_to_heading_angular_vel
1.8
Angular velocity for orienting toward the path heading.
use_velocity_scaled_lookahead_dist
false
Disables scaling of lookahead distance based on velocity.
use_collision_detection
true
Enables obstacle detection for safer navigation.
max_allowed_time_to_collision_up_to_carrot
1.0
Maximum allowed time to potential collisions along the path.
min_approach_linear_velocity
0.05
Minimum velocity when approaching a goal or obstacle.
transform_tolerance
0.1
Tolerance for transform lookups to ensure stability in real-time adjustments.
The robot’s performance was evaluated under three scenarios using this combination:
  1. Straight-Line Movement - The robot navigated smoothly and efficiently, adhering to the global path without significant deviations. - Velocity regulation ensured stable and precise motion.
    Straight-Line Movement GIF
  2. Navigating Static Obstacles - Performance was suboptimal, particularly when passing through close gaps. - The robot struggled with efficiency compared to other combinations like NavFn + DWB and NavFn + MPPI.
    Static Obstacles GIF
  3. Navigating Dynamic Obstacles - The robot managed to replan and avoid moving obstacles, but the response time was slower than other controllers. - While it successfully reached the goal pose, the delay in path adjustments indicated limited efficiency in dynamic scenarios.
    Dynamic Obstacles GIF
Performance Summary
Performance Summary
Scenario
Performance
Smooth and precise navigation, ideal for open spaces.
Static Obstacles
Struggled with close proximities, less efficient compared to other combinations.
Dynamic Obstacles
Slow in replanning and path adjustments, though able to reach the goal.
Conclusion
The combination of NavFn Planner and Regulated Pure Pursuit Controller is well-suited for open environments with minimal obstacles. However, its limitations become evident in more complex scenarios, such as navigating through tight spaces or reacting to dynamic obstacles.
Future Improvements: - Consider using DWB or MPPI for environments with close proximities or high dynamic activity. - Fine-tune parameters like lookahead_dist and enable velocity-scaled lookahead for more responsive adjustments.
To better understand the communication between various components of the Nav2 stack, here’s the RQT Graph visualization of interconnected nodes. This includes key nodes like the local cost map, global cost map, controller server, planner server, and behavior server.
RQT Graph Visualization
The RQT graph illustrates how these components interact to ensure smooth and efficient navigation. Each node plays a critical role: - Planner Server: Computes the global path. - Controller Server: Adjusts the local trajectory for real-time obstacle avoidance. - Behavior Server: Manages higher-level behaviors like spinning, backing up, and driving on heading. - Cost Maps: Provide the environmental representation for planning and obstacle avoidance.
This interconnected structure ensures seamless communication and dynamic adaptability during navigation.
Previous Next
© Copyright 2025, MyBotShop GmbH.
